How to supply a 1mA input and read a mv output proportional to the input current
Is there a way to create a constant 1 ma input to a sensor and then read a mv output that is proportional to the input current? I am wanting to run a pressure sensor and the supplier says the nominal input is 1.0 mA (1.5 ma max) and the output is 0 to 50 mv but it proportional to the input current. I would like to store the input and output data to make decisions for control of another device. I would like to store the last 10 readings in such a way that they will be in memory when the board is disconnected from power and then powered back up again. The schematic of the pressure is located at this website: http://meas-spec.com/downloads/23_33_Std.pdf
Its set-up to read T/C but with some hardware mod's it should do what you need.
http://www.mouser.com/Search/Refine.aspx?Keyword=ds2760
What the manufacturer is telling you is that a varying input to the measuring bridge will affect the output. As long as it is relatively stable, your output will vary correctly with pressure.
There should be some sample circuits available from the manufacturer.
Cheers,
