MMA7455 Accelerometer/Basic Stamp 2 Troubles
Hi All,
I'm new to the Basic Stamp 2 module and the programming with it. To work around this, I am attempting to setup the accelerometer to read out the XYZ coordinates of my Board of Education as I change its spatial position. The demo code from the MMA7455 site is NOT working out too well for me: http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/mma7455/List/0/SortField/4/ProductID/585/Default.aspx.
I have followed the instructions at the top of the demo:
How I interpret this: I have probed VIN - it is getting 5.04V, VSS is getting 4 mV. P0 is connected to the CS pin, P1 is connected to the DATA pin, and P2 is connected to the CLK pin. Is there some other issue that I am not seeing here? Does something else need to be set up?
Thank you for all help in advance - most appreciated.
- ButterflyKittens97
'How TO Use:
' o With power initially off, connect VIN TO 5VDC (the same voltage
' powering the sTAMP). Connect GND TO Vss.
' o Connect P0, P1, AND P2 ON the Stamp directly TO the CS, DATA, AND CLK
' pins ON the Digital 3-Axis Accelerometer module.
' o Power ON the Stamp. Download AND run this code ON the Stamp.
Did switching the connections to P0 and P2 help fix the issue? I am trying to figure this one out - no luck...
Edit: Backwards in the directions at the top of the BS2 demo programs for P0-P2 connections only.
Thanks for all help in advance - most appreciated!
