No stamp found error
<font size="2">I have a PC with carrier board for BS1-IC via BS1 serial adapter. I have a straight through serial cable that tests ok. The BS1-IC regulator is making 5 Volts but the stamp doesn't communicate with the PC. When I run "Identify" loopback and echo say NO. When I select "edit ports" it indicates both port 5 and port 6 are present. Device manager says both ports are working normally. Any suggestions?</font> <br>
<br>
<span style="font-family: Arial;"><font size="2">K.C. Jones</font></span>
<br>
no loopback = no connection, it's just a jumper on the BS1 adapter.
If you're using a USB-serial adapter, it may not be one that uses pin4 and/or 7.
The adapter is the 9-pin type. To check the serial cable I ran the stamp editor Identify utility with serial connector pins 2 and 3 shorted and it indicated: Loopback NO and Echo YES. I assume this is what it should read. Is there a way to check the adapter through the carrier board to see if there is a path to the stamp. As I said, the regulator on the BS1-IC is furnishing a solid 5Volts so power shouldn't be an issue.
K.C.
I think it's your USB-to-serial(9pin) adapter, it may not be working pins 4, 7 (not all of them do.)
K.C.
K.C.
And your cable is 100%?
And you're certain there's no conflict with another app on that/those ports?
And your power source is rock-solid?
If all that's affirmative,
You could try situating everything on a breadboard in acc. with my dwg in #2, maybe it's the carrier. If it doesn't happen there then it's the Stamp or the Adapter.
Shouldn't be this hard.
