OBC's "Funtendo" on HackaDay!! — Parallax Forums
Jimmy W.Jimmy W. Posts: 112
edited 2011-12-02 07:32 in Propeller 1
Just thought I would post this here, Props(pun intended) for making news and promoting the prop platform and gadget gangster!
http://hackaday.com/2011/11/30/funtendo-connects-all-your-nintendo-controllers-to-a-pc/
Jimmy
  • SarielSariel Posts: 182
    edited 2011-11-30 11:45
    Simply awesome. I remember a long time ago modifying an 8 bit controller to use the "old school" 15 pin joystick port found on old sound cards. This is a great way to do it without destroying the controller in the process. I could not find a link towhere I could purchace this item, or download some source code/schematics. Anyone out there willing to share some info? OBC?
    (woohoo! first star!)
    edited 2011-11-30 14:22
    Thanks Jimmy!
    @Sariel, No controllers were harmed in the making of this project. I purchased cheap extension cables for each of the controllers off Ebay. The extensions cost around $5.00 each. Never saw that 8bit to PC adatper. Sounds cool, but few newer PCs have that DB15 connector anymore.
    OBC
    edited 2011-12-02 04:27
    yeah, that is why it is in a box somewhere in my garage. It worked awesome with NESticle back in the day using just the standard "Gravis" drivers that were bundled with Win95. Unlike your project, I did really mutilate the PCB inside the gamepad. Removed the IC, cut traces, added a couple transistors and a couple resistors... I would really have to dig to find the schematic, but I suspect the intrest in this is quite low.
  • Beau SchwabeBeau Schwabe Posts: 6,571
    edited 2011-12-02 06:21
    OBC,
    Cool project, way to go! :-)
    Thanks Beau
    I had some great supporting objects for this project! :)
    OBC
