Sharp GP2D120 IR Range Sensor - 4 to 30 cm
air250
Has any one tried to put the Sharp GP2D120 IR Range Sensor - 4 to 30 cm or any thing close to it on the boe-bot and if you have how did you do it, there are only three ports so im not sure how you would be able to set the freqout and receive a value as well
The sensor outputs an analog voltage corresponding to the distance of the object, and can easily be read using an inexpensive analog to digital converter (ADC) chip.
It does not operate like the PING)) module which you transmit then listen. You only have to read the voltage off the module.
