XBee Wireless Pack - Pricing question.
I was looking at the XBee Wireless Pack http://www.parallax.com/Store/Accessories/CommunicationRF/tabid/161/ProductID/785/List/0/Default.aspx?SortField=ProductName,ProductName that costs $99.99 I added the individual components up and the cost is about $75. Why is the XBee Wireless Pack $25 more?? What do you get for the extra $25?
-Tim
-Tim
A USB cable and packaging, as this product is mostly designed for our retail outlets. As you know what pieces you need, simply go for the parts as you proposed.
-Tim
after you click "Edit Post", click "Go Advanced" to the bottom right of the edit area, then in the second row under towards the top of your message you should be able to select prefix and change it from "UNSOLVED" to "SOLVED" Then save.
Hope that helps.
Doc
-Tim
