USB port on a Stamp
Hi folks,
Like most of you, I have used a USB converter plugged into a laptop in order to program a Stamp via its DB9 serial connector.
I now have a situation where the customer is changing his bar code scanners to a model only available with a USB connection. This means I need a way to make the Stamp appear as a USB master.
Does anyone know of a USB adapter that can perform that function?
http://www.sparkfun.com/products/9947
Thanks to Phil, Leon, Zoot.
Good points; I'll check out the barcode scanner and see which chipset it contains.
Tom
If the client agrees to a trial, I'll report the results.
Cheers,
Jeff
That said, I don't quite understand what you're trying to do. Can you give an example? Remember that the Vinculum chip can only handle one file at a time.
Creating folders on a thumbdrive using the Parallax datalogger or similar is not too difficult, creating your own Topic/thread will get you more help.
Jeff T.
