QS Board strange behaviour from touchpads
This has been resolved from another post titled " QS Board programming the touchpads"
Following on from my other post using the touchpads on the Quickstart Board, I have noticed a strange anomaly with using the INA command.
Here's the code being used:
The designated pad will run the led chase but I have also noticed that any value of 0,1,or 2 used in the If (INA
[*]==1 (substitute value for *) statement will also allow the two pads to the left of the designated pad to run the chase also if pressed together this only works up to 2, 3 to 7 are ok and only the designated pad will run the chase.
Is there some mathmatical summing of input bits causing the problem or a hardware problem as it only works with the lower buttons not the higher ones?
Is there some piece of code that avoids this problem that I havn't read about yet?
CON _clkmode = xtal1 + pll16x _CLKFREQ = 80_000_000 VAR byte time PUB LedCounter time:=4 dira[16..23] :=111111 repeat If (ina[0] == 1) outa[16..23] :=1 waitcnt(clkfreq/time + cnt) outa[16..23] :=2 waitcnt(clkfreq/time + cnt) outa[16..23] :=4 waitcnt(clkfreq/time + cnt) outa[16..23] :=8 waitcnt(clkfreq/time + cnt) outa[16..23] :=16 waitcnt(clkfreq/time + cnt) outa[16..23] :=32 waitcnt(clkfreq/time + cnt) outa[16..23] :=64 waitcnt(clkfreq/time + cnt) outa[16..23] :=128 waitcnt(clkfreq/time + cnt) else outa[16..23] := 0
The code that posted in the other thread should work from pins 0 - 7 only and that's because the touch buttons are connected to these pins only.
BTW, you didn't need to start another thread for this problem since it's still related to the one you started earlier.
I understand about the buttons being 0-7 my post above has probably confused everyone, I wasn't trying to suggest that there were more input pads than those but that the command seemed to do funny things up to INA[2], INA[3] to INA[7] worked fine, still don't understand why they worked at all given what Ariba was saying about charging the pins capacitor first but they did up to a fashion.
Mybe there is stray capacitance always around the pins until you put them into a known state by charging first? hence why some pins worked together to trigger the chase? Just guessing here, perhaps the hardware guys have an answer?
What I would suggest you to do is download the Quickstart PDF so you can look at the schematic to understand how the propeller is connected to everything on the board.
