Christmas Tree Light Controller
Ok so here is my latest project. I have 6 dip switch packs that enable or disable certain sub routines each subroutine is a pattern for the lights. I have a trim pot and an rctime command to controll the overall speed of the patterns and then i have 8 outputs that bias transistors and have leds on the output of the transistors so i know what chanel is active (to help troubleshooing code) the SSRs i currently have are ones found lying around. They are kindof big but do the job... kind of.
here is my question. The minimum on current for these SSRs is 100ma. I am using LED lights at strand of 100 of them only draw 50ma for on half of the cycle. I currently have a 1kohm resistor to get 120ma load continuously. The resistors are 15w and get significanly hot. At this point of the circuit the efficientcy is completely thrown out the window. I suppose i need to rework this. I need to know if there are any SSRs that would supply around an amp or two of current that are maybe a lot lower in minimum current requirements. I looked at the sharp SSRs on parallax website but no specification is mentioned of minimum current. I want to be as efficient as possible so i was thinking a 10ma or lower minimum current and then maybe a resistor and a diode to keep the current going on the oposite side of the waveform.
What should i use? Circuit ideas?
You could also look at the IRL510 FET...Its fully on with 5volts at the gate.
http://www.sharpsma.com/webfm_send/304
http://www.vishay.com/docs/91297/91297.pdf
Any insight to this ???
