PCB Question
Hey All...
I've been building a few circuits on perf-board and I'm really not happy with the results. Most of them have worked, but look like... well, they're way ugly.
I kinda want to venture into making my own PCB boards. Nothing too complicated... less than a dozen discrete components. Just wondering if anyone has favorite leads for "beginner kits", supplies or how-tos to do this?
Many thanks for your input!
Amanda - Happy Thanksgiving!!!!!!
http://tech.groups.yahoo.com/group/Homebrew_PCBs/
You can make your own equipment quite cheaply. Some of the PCB suppliers are now so cheap that it might not be worth making your own boards, I've had good results with ITead Studio:
http://iteadstudio.com/store/index.php?main_page=index&cPath=19_20&zenid=qa08tp07o8bn54mjpo155e5o16
Free Schematic and Board Layout software. Fast turnaround; not the cheapest, but very handy.
Jim
Probably the easiest way to make your own circuit boards is with the toner transfer method. You can find a lot of information pertaining to this subject on the internet. It is always the same basic principle, however there are some that use slightly different techniques to achieve better results. You just have to look around to find what works best for you.
Bruce
It is b-n Kiev and Odessa.
Just so you know
Eagle (light) the free version can make double sided board files, up to ~4" square (I think)....And there are great tutorials on you-tube for making your schematic/board.
I got some boards done from Dork-bot http://dorkbotpdx.org/wiki/pcb_order they are nice quality and made in the USA.
I do not agree with your philosophy.
Let's say you want a 3" X 3" board. At the price you quote, that is a minimum of $135, plus you have to wait for the boards to arrive. Either way, you must design the board before it can be made, and by the time you order a board and have it delivered, you can learn the toner transfer method and have your board made, providing it is not to complicated. As far as the plated vias go, simply drill a through hole between the top and bottom wire traces that you wish to connect and solder a piece of wire.
Unless it is illegal, learning something new and saving quite a bit of money is never a bad thing.
Bruce
And its ok not to agree with the philosophy. I have talked in great detail with others about this. They have started with DIY PCB's and if they had a service like this available to them, they would have not bothered trying to make low quality boards themselves.
Less than a dozen components and toner transfer sounds like a match made in heaven
This is a picture of the first PCB I had done professionally.
