motor control
I'm using a stamp to control a motor. The motor accepts a position (P) value to determine how far to spin the shaft. For one revolution, P = 50,000. I am typically sending P = 1000000 for twenty revolutions, but I'd like to be able to modify the P value depending on the situation. I send a command such as SEROUT 1, 500, [Enable, CR, "P3=1000000", CR, "[3", CR] where "enable" activates the motor to receive the P value, P3 means I'm working in a certain bank of speed, accel and position values, and [3 confirms the P value and initiates the move. I'd like the P3 value to be multiples of 1000000 in different situations, but I cannot figure out how to cause the stamp to change the value in the SEROUT statement once I've derived the multiple (an integer from 2 to 20) to use.
It would help to better understand the problem!
