433MHz Transceiver Issue with bs2
I am using a BS2 developer board connected with a 433 mhz wireless transceiver (27982). I have two seperate boards connected by way of the serin and serout commands communicating successfully using the wireless transceivers, however, I have noticed that when in receive mode, one transceiver is consistently receiving garbage bytes from an unknown source. A spectrum analyzer was unable to locate any radio interference in the room, and even with the antenna off the receiver, it was still spitting out junk data. While the two transceivers are capable of communicating, and transferring data, while using a serin command with a wait modifier to ensure I do not receive the junk data, I cannot use a timeout function on this serin, because the junk data prevents it from timing out.
This happened using both transceivers in the same position, with the other one completely off, and no detected radio inteference by the spectrum analyzer. I also tried connecting it to a board that didn't have my other components connected to it, to remove that as a possible problem, still did the same thing.
Is there any additional infromation on the transceiver that I don't know about? Are they maybe, designed to never output nothing on the serial connection? As long as that serin command is unable to timeout, I am unable to interrupt my wait for the information from the sending transceiver. If an error occured during transmission both systems would lockup waiting for input data from eachother.
Another option, since the noise pulses are short, would be to put a tight loop in your program before the first SERIN that would look for a period of time (a certain number of successful loops) with a high signal from the sync pulse. Every time a low signal comes in, the counter would get reset to zero. Once the counter gets high enough, the loop would exit to a SERIN with a timeout which should work at that time. Your sync pulse would have to be a couple of character times long (2ms each at 4800 Baud) to ignore unexpected data transmissions.
You could also look at the voltage on the RSSI line. You'd have to do some experimenting to see what sort of voltage is present with a sync pulse of a particular width. You could set up a simple comparator or use the RCTIME statement to read the voltage and use that to indicate when the sync pulse is present (see here, follow links to "app-notes" and "RCTIME command").
FXDWG
