PropBasic 4x4 Keypad Code
I am trying to read a 4x4 keypad using PropBasic with
no luck. Does anyone have code for this that they
would share? thanks for your help
As a total guess I would think you would use four pins for rows and four pins for columns. You would set a row pin high and read the column pins, and repeat for the other row pins. You might need some current limiting resistors as well.
