Programming PIC12F629.
I have the Propeller Educational Kit that comes with the Propeller plug (USB -> Serial) to interface/program the propeller from the USB port (not sure what to call it). Now I want to start playing with PIC12F629. Do you know if I can program it with the USB plug that comes with the Propeller kit, or do I need to buy a programmer for it?
The Prop doesn't program as such, it just passes the code to an attached EEPROM at 3.3 Volts. There are loads of circuits about that use serial or parallel ports.
Frank
Thanks Leon. I followed your advice. I have to say that learning the Propeller was a lot more enjoyable experience, I think mostly because the "Education kit labs fundamentals" manual is very well written compared to the tutorials that came with the PIC. Just wanted to share my experience with you and to say THANK YOU Andy Lindsay for writing such a helpful and clear manual.
