Update serial cable to usb cable — Parallax Forums
iteasdaliteasdal Posts: 1
edited 2011-11-20 17:46 in General Discussion
All, I'm a newbie. Several years ago I bought the Basic Stamp "What's a Microcontroller?" package. My oldest son wasn't interested, but now a younger son is. The version I have only has a serial cable to go from the computer to the microcontroller. I have a laptop that doesn't have a serial port. If I go buy a "Serial to USB" cable, will that work? or do I need to get something else?
Thanks for your help!
    edited 2011-11-20 15:12
    Not all cables work, it's hit & miss. The Parallax one does, obviously, if you want to order it and wait. I believe someone posted that one sold by Radio Shack works, if you're in any rush.
    edited 2011-11-20 17:23
    I have a thread running over on the Propeller forum where we are trying to work out exactly why some cables do not work. We are getting close to a solution for the propeller and in the process have discovered that some cables don't use proper RS232 voltage levels. Officially, RS232 resting volts are minus 3 to minus 12V (or more). And an active signal is plus 3 to plus 12V (or more). Some cables have resting volts as 0V which is an invalid RS232 voltage level.
    We are still trying to find a workaround so the quick answer would be to get the cable that we know work as erco suggests. I'd get one from Parallax as then you can be sure.
    Check this post for more info: http://forums.parallax.com/showthread.php?133195-USB-Adapter-Fix
    I got several adapters working for PicAxe (3-pins), but I haven't yet tried a 4-pin adapter for a Stamp.
