Video Input Switching — Parallax Forums
jdoleckijdolecki Posts: 726
edited 2011-11-20 09:09 in Propeller 1
How would I switch several cameras to one output with a propeller.
Is there a video switch chip out there?
thanks
    edited 2011-11-19 16:50
    Did you try DigiKey's "Search" function? That's the first place I go when looking for a specific kind of chip.
  • jdoleckijdolecki Posts: 726
    edited 2011-11-19 17:13
    Hey Phil
    I noticed you little emblem on the back of my Propeller Backpack
    Did you design that?
    edited 2011-11-19 17:22
    Yup!
    edited 2011-11-19 22:21
    jdolecki wrote: »
    thanks
    Maxim used to have a line of them. I have one 8 channel video mux from a ways back they sampled me that is currently residing in the someday I'll pile on my desk somewhere........
    Frank
  • Jack BuffingtonJack Buffington Posts: 115
    edited 2011-11-20 08:48
    Keep in mind that unless you genlock (sync together) your cameras, you will have a glitch of a frame or two if you simply switch between them. You can get around this by buffering frames and keeping them synced yourself but I think that is beyond the ability of the propeller. On the plus side, if your cameras are able to sync to a master clock, the propeller is easily capable of generating LTC and VITC timecode!
    If your cameras run from 12VAC, which many security cameras do, they will automatically be locked to the AC power line frequency. As to the switch, you might take a look at the schematic for the Propeller Backpack. It uses back-to-back MOSFETs to switch the incoming video stream in and out of the output for overlay purposes. The same technique might work in your app.
