New to programming, need help turning a motor
okay, so this is my first time on this website and i struggled to find anything that answered my problem. Sorry if this is the wrong topic area, but it seemed to fit.
To start off with some background, my classmate and i are doing a miniproject so to speak in our allied tech engineering class. We had never, ever even used any programming code before and kind of threw ourselves into unknown waters with this project. The goal was that this project can be set up in a hallway and detect people that walk by. When the people are detected, a motor spins a transmission, raising a head on a rod. That head would then look around the hallway then return to the resting position.
All the coding has been done in BASIC Stamp 2.5 and a Board of Education Microcontroller.
So far in programming we have successfully coded the raising, holding and dropping of this rod and head. However, what we cant do is that when the rod is holding in the upright position, a second motor will run and spin the head. unfortunately, the code is on a school computer and we cannot access it, but the code is some what simple.
it is something like:
IF IN0 = 1 THEN
duration = duration - 100
ENDIF
we have this setup for all possible combinations that require action from sensors. however, when the rod goes up to a holding state, we can get the motor to spin the head, just not evenly. What kind of code should we be writing in the subsystem for it to run evenly in both directions(forward and reverse)? or even better, how can we say something like, turn 85 degrees, turn 170 degrees reverse, turn 170 degrees forward, turn 85 degrees reverse, return to main program?
Any help is appreciated. i understand the post is long and can seem confusing so just ask for clarification where needed! thanks!
IF IN0 = 1 THEN
ENDIF
I should've stated this earlier, but the motors are being run by 2 GEARS EDS Speed controllers, one for each motor.
http://guides.machinescience.org/file.php/29/GRS/LEDAnimation.gif
For IN1 and IN2, these are just simple switches that work like limit switches. they look a lot like http://rocky.digikey.com/weblib/Omron/Web%20Photo/SS-5GL.jpg
It is a little hard to understand through words, but on the transmission when the code runs, there is a piece of metal that will spin on the axle that hits these switches and when the switche is hit, the motor stops.
I'm not sure if you are familiar with the What's a Microcontroller? book, but this code was modeled straight form one of those.
We have all of the main program running properly, we just do not know how to the motor run evenly. The area of the code in question reads something along the lines of:
Main Program
DO
IF IN0=1 AND IN1=1 THEN ' meaning the motion detector and the limit switch for the upright position is tripped.
GOSUB Spin 'Here we want the code to move to the subprogram below
ENDIF
Subprograms
Spin:
duration = 750 'this keeps the first motor from spinning, while keeping a pulse through the first speed controller.
For X = 1 to 1000
For x = 1 to 500
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/CategoryID/51/List/0/SortField/0/Level/a/ProductID/83/Default.aspx
the limit switch is something similar to
http://rocky.digikey.com/weblib/Omron/Web Photo/SS01GL13D, SS5GL13D.jpg
and the motors are run by this speed controller
All of the programming runs perfectly except for this section. It is something along the lines of
IF IN0 = 1 and IN2 = 1 THEN 'IN0 = 1 means the motion detector sees people and IN2=1 means the
GOSUB Spin 'transmission is at its highest point
ENDIF
Subprograms
Spin:
duration = 750
For x = 1 to 1000
For x = 1 to 500
pulsout 12, 500 '12 is the constant for the second motor
NEXT
For x= 501 to 1000
pulsout 12, 1000
NEXT
NEXT
RETURN
This program is attempting to get a motor to run in one direction evenly, then another for the same length of time
It may not be exactly correct, but i cannot access the code itself for about 40 hours. Anything you could understand form these two posts is greatly appreciated, but if not i understand completely!
If your motor controller is supposed to behave like a servo motor and respond to pulses from roughly 1ms to roughly 2ms, your problem may be that the pulses are coming too quickly together. For a servo motor, there needs to be a 20ms pause between successive pulses and you don't have any pause in your program except for the execution time of the FOR / NEXT statements which isn't much. Put a PAUSE 20 after each PULSOUT and see what happens.
