BS2e SPRAM — Parallax Forums
BS2e SPRAM
Rod_NSCCRod_NSCC Posts: 5
edited 2011-11-18 17:45 in BASIC Stamp
Can you use the SPRAM on the BS2e for variable storage?
    edited 2011-11-18 08:32
    No
    You can store data there by copying it back and forth from variables using GET and PUT, thus freeing up the variables to be used for other things at different times in the program, but no, you can't access the SPRAM as if it were ordinary variable storage.
  • cgxcgx Posts: 4
    edited 2011-11-18 16:04
    You can go even further, let me tell you; if you drill a whole in the middle of the chip you can plug your earphones and use it like a MP3 player.
    Note: In my case a use 1/8 drill
  • Rod_NSCCRod_NSCC Posts: 5
    Thanks Mike! I appreciate the quick reply.
