Prop Tool (IDE) fonts overlap? — Parallax Forums
Roger LeeRoger Lee Posts: 339
edited 2011-12-23 21:51 in Propeller 1
Using Propeller Tool v1.3
Windows XP
The fonts just went all weird on me.
characters sort of compressed and walking on top of each other.
What did I do, and how do I fix it.
Thanks.
Roger
630 x 495 - 57K
    edited 2011-11-18 06:11
    Judging by the look of the $ character, that's not the Parallax font. Can you check if it's still installed on your machine?
  • RiJoRiRiJoRi Posts: 157
    edited 2011-11-18 07:07
    This happens to me in the CODE boxes. I believe it's a result of making the fonts larger in FireFox for these aging eyes. I can live with it by copying any code I am interested in to my editor. (EditPlus, IIRC)
    I suppose I could use Ctrl+GreyMinus to make the fonts smaller, but then I couldn't read the code!! :D
    Add: Rereading your message, I see you are most likely using the Prop editor, but the principle should be the same.
    --Rich
  • Roger LeeRoger Lee Posts: 339
    edited 2011-11-18 09:59
    It appears the Parallax font is corrupted.
    This screen shot is from Control Panel/fonts/Parallax(TrueType).
    684 x 597 - 93K
  • RaymanRayman Posts: 16,457
    edited 2011-11-18 10:50
    I've never seen that happen before... I'd try reinstalling the Prop tool...
    edited 2011-11-18 11:25
    It happened to me once. IIRC deleting then reinstalling the Parallax font fixed the problem. Also, you might want to switch to the tweaked Parallax font while you're at it:
  • UnsoundcodeUnsoundcode Posts: 1,532
    edited 2011-11-18 11:31
    Hi Roger, it has happened with others too, there are several threads out there, heres a link to one thread where I had the same thing
    Jeff T.
    http://forums.parallax.com/showthread.php?98307-IDE-text
    edited 2011-11-18 13:29
    Thanks for all the suggestions.
    I did a reinstall and things look good now.
    Roger.
  • Dave MatthewsDave Matthews Posts: 93
    edited 2011-12-23 11:58
    By golly this just happened to me today! Went to the Forum, found the thread, uploaded tweaked font...All is well!
    Thanks everyone!
    Dave KI4PSR
    Glad I could help you, even if indirectly.
    Roger..
