I need help with my code.
' {$STAMP BS2}' {$PBASIC 2.5}
z VAR Byte
y VAR Byte
x VAR Byte
HIGH 0
PAUSE 500
a:
LOW 0
SERIN 1, 2400,[x]
HIGH 0
READ 0,y
IF x=y THEN
TOGGLE 11:TOGGLE 13
ENDIF
IF x<>y THEN
READ 1,z
ENDIF
IF x=z THEN
TOGGLE 11:TOGGLE 13
ENDIF
IF x<>z THEN
HIGH 15
PAUSE 500
LOW 15
ENDIF
PAUSE 250
GOTO a
It'll read the tags and EEPROM. But it won't compare the variables.
Before you ask again, please add some comments to your program that explain what you're trying to do. It helps you and it helps us help you. Also note that the compiler directives at the beginning each have to be on their own lines.
' {$STAMP BS2} ' {$PBASIC 2.5} z VAR Byte y VAR Byte x VAR Byte HIGH 0 'Disable RFID device PAUSE 500 'Wait 500ms a: LOW 0 'Enable RFID device SERIN 1, 396,[x] 'Read serial data from RFID device HIGH 0 'Disable RFID device READ 0,y 'Read value stored in address 0, store as "y" IF x=y THEN 'Compare stored value and tag value, if equal TOGGLE 11:TOGGLE 13 'Change logic state of pins 11 and 13 ENDIF IF x<>y THEN 'If tag value does not equal stored value READ 1,z 'Read address 1, store as "z" ENDIF IF x=z THEN 'If tag value equals stored value TOGGLE 11:TOGGLE 13 'Change logic state of pins 11 and 13 ENDIF IF x<>z THEN 'If tag value does not equal stored value HIGH 15 'Change state of pin 15 to logic 1 PAUSE 500 'Wait 500ms LOW 15 'Change pin 15 back to logic state 0 ENDIF PAUSE 250 'Wait 250ms GOTO a 'Go back to aIs that better? If the directives are still on one line, I don't know why. They're on two.
