ZoopyDogSit clear out get them while I'm in an anti-hoarding mood ;-)
Welcome, It seems that the hoarding bit has been reset, so I'm in the mood for clearing out lots of stuff I've been hoarding.
I'll edit and remove stuff when sold, and add as I dig more stuff out of my cupboard and shed.
I'm not going to price stuff, just IM me with what you want and what you think is a reasonable price and we'll see if we can come to an arrangement. I'm not doing this to make a profit. Also please note these parts are in Australia, so if you don't mind slow shipping then the costs will be reasonable, alternatively if more than one person state side wants items I can bulk ship to one and they can re-distribute to hopefully reduce the shipping costs.
For the cash restricted buyer I may be willing to trade, there are items that I'm looking for and would happily swap, ie. nice sized old air gap variable capacitor (like in an old valve radio - want a working one for a crystal radio to build with my nephew). etc.
Tube stock (in manufacturer tubes)
40 x HLMP-2885 Green indicator blocks. These are about the size of a 16 pin dip chip, you can stencil on them, ie. "Online"
http://pdf1.alldatasheet.com/datasheet-pdf/view/125644/HP/HLMP-2885.html
100x HLMP-2685 Red indicator blocks. These are about the size of a 16 pin dip chip, you can stencil on them, ie. "Error"
http://pdf1.alldatasheet.com/datasheet-pdf/view/125626/HP/HLMP-2685.html
200x ST TIP47 1A power transistors.
http://pdf1.alldatasheet.com/datasheet-pdf/view/25376/STMICROELECTRONICS/TIP47.html
150 xTMFM5380 38KHZ IR Reciever modules
http://pdf1.alldatasheet.com/datasheet-pdf/view/26102/TEMIC/TFMS5360.html
22 x K6T1008C2E 128Kx8 70ns Static Ram chips
http://pdf1.alldatasheet.com/datasheet-pdf/view/37101/SAMSUNG/K6T1008C2E.html
200 x ILQ5 Quad Opto couplers
http://pdf1.alldatasheet.com/datasheet-pdf/view/45334/SIEMENS/ILQ5.html
150x HFC4066BMI. SMD Quad analog switches.
90 x Max147BCP 8 channel 12 bit serial A-D converters
http://pdf1.alldatasheet.com/datasheet-pdf/view/72828/MAXIM/MAX147BCPP.html
20x X28HC64J-12 8Kx8bit Eeprom
http://pdf1.alldatasheet.com/datasheet-pdf/view/34312/XICOR/X28HC64J-12.html
100x CAT28C648J-15 SMD, manufacturer CSI 8Kx8 eeproms
Can't find the datasheet, feel free to look.
Loose stock (in bags/boxes/draws)
150x 292907A Transistors To-18 metal can style
http://pdf1.alldatasheet.com/datasheet-pdf/view/15073/PHILIPS/2N2907A.html
Cheers,
Dave
Cheers,
Dave
There are several sites that show how to make our own. Here is one http://www.eham.net/articles/5217
I could use the indicator blocks. PM sent...
Robert
