No power to Basic Stamp???
I am currently in a class where we are programming with the basic stamp kit. I have the Basic Stamp 2 homework board, (yes im a newb). Anyways, i am not getting any power to my stamp, i have had it for about 3 months and am always cautious with it (static) and what not. I was hooked up to a power supply with 9 volts because my battery was dead, and everything was working fine. I disconnected power to make adjustments on my stamp, then went to turn it back on and no power at all. This has happened to me once before, i gave it 12 hours and it then worked again just fine. Is this board toast or what? Anyone have any troubleshooting options? Thank you.
You should find 5V between Vdd and Vss jumper sockets on the HomeWork Board at the top of the breadboard area.
If Andy has a laptop, what about that USB latency adjustment thingy? (I forget the correct words)
You helped me with a similar sporadic problem on my laptop when I first started out.
@Andy - go here:
http://www.parallax.com/Accessories/USBDrivers/tabid/530/Default.aspx
and click on the "trouble shooting" link at the bottom of the page. It will pull up some informaton concerning USB port configuration, that if not setup properly, can cause sporadic recognition and download to the Stamp.
Also, make sure that the FTDI drivers referenced on the page are installed.
Let us know what happens?
