LM2940 direct replacement for LM7805?
I have a project I am tinkering with that needs to run the SX28 at 50Mhz. When everything is hooked up, the 7805 will stop putting out power on first boot. The power source is a 16v solar array I have assembled. There is one circuit that detects the power from the solar array and when over 13v, it turns on the SX28 circuitry which controls a small 6v DC motor using a mosfet and PWM. Once the SX28 turns on, it displays a sequence on an 7 segment display, then rotates the motor for 2 to 5 seconds. Everything works until a cloud appears. The voltage drops to 13.5 to 14.2 and the entire SX circuit dies. Could I simply pull the 7805 out and replace it with a 2940 with no other modifications? If there are mods, what would need to be changed?
You also have to pay attention to the capacitance tolerances. If the minimum required capacitance is 22uF, a capacitor rated at 22uF +/- 10% may not do the job; one rated at +20%/-0% will be okay.
