Bought new computer and now editor wont identify the board
I bought a new machine and installed Editor v 2.5.2. I'm using the same generic USB to Serial adapter, same board same stamp, same code... But my editor wont identify the board. I get "no echo no loopback" when I attempt to identify. Any ideas??
Welcome to the forum!
I think you will need to delete whatever USB/serial drivers you installed and start over with the FTDI drivers from Parallax's website.
I'll give it a try again tonight, but last night when I initially installed 2.5.2, the Parallax drivers wouldnt recognize the generic USB/serial cable.
The issue is that many "cheap" USB to serial adapters don't completely implement some of the control lines like DTR which Parallax uses for programming their microcontrollers.
I'll check the old laptop driver for comparison. The this very same setup worked fine with XP sp3 and whatever drivers XP had by default and XP recognized and used the USB/serial adapter without any hiccups. There's been no change at all in the configuration of the Stamp equipment.
Does the parallax USB/serial adapter work with Windows 7?
Absolutely! With the:
http://www.parallax.com/Store/Microcontrollers/PropellerAccessories/tabid/786/CategoryID/85/List/0/SortField/0/catpageindex/2/Level/a/ProductID/398/Default.aspx
. I use it with Windows 7 32 Bit and 64 Bit
Jim
I'll order a new adapter from parallax tomorrow.
To run as administrator, right-click the Stamp IDE shortcut and choose "Run as Administrator", or select Properties for the shortcut and look for the same setting.
Note that you'll also need to do this with other programs that access the serial port, such as Putty.
Yeah, I have no shame so here goes...
It's been so long since I've played with this dev board, that I've been plugging the USB/RS232 adapter into the WRONG 9 pin D-connector all this time. Clever of me to use the port labeled "RS232 Interface" instead of "DOWNLOAD" dontcha think?
Problem solved!!
Facepalm*
