Crypto Demo: DES / RSA
Reinhard
I myself are surprised, that the crypto routines from the book "MasteringAlgorithms with C" by Kyle Loudon,
published by O'Reilly & Associates run with propeller-elf-gcc and minimalistic adaptions.
In the attached zipfile is a mk.bat for easy compile and run (under windows).
best regards,
Reinhard
best regards,
Reinhard
Nice find, Reinhard, about DES and RSA. Thanks!
the DES algo is sometimes implementet in hardware, it is a huge XOR orgy.
In the demo a 8 bit key is used, usually in commercial application a TripleDes (24 bit) is used.
But the princip is the same, needs only more memory.
The RSA is quite simple math, see: http://en.wikipedia.org/wiki/RSA_%28algorithm%29
but hard to implement on small processors.
the algo based on finding very large prime numbers,
in the demo is calculated with small numbers. ( but the princip is the same)
Maybe the independents cog can used to find primes with a clever algo!
best regards
Reinhard
