power supply
mmoreland
Is it a mistake to power a BS2p using a 7.5vdc wall adapter that has been modified with a 9v battery snap and attaching it to the 9v battery port on the stamp board? More importantly, was the stamp likely damaged when I attached the power supply with the voltage polarity reversed for a few minutes before realizing my mistake? The stamp accepts the code and runs the program, but the SLEEP function appears to have been disabled. Does that make any sense?
As you rather painfully found out, when you wire up a battery eliminator using a 9V snap, the polarity gets reversed. You aren't the first and you won't be the last. The good news: you (probably) won't ever make that mistake again.
20-20 hindsight is all too clear: test continually with your multimeter and work slowly & methodically.
