Mouse cursor keep moving whenever I connect Stamp 2Pe motherboard (Mobo)....
I am trying to install and connect BASIC stamp 2pe motherboard called Mobo. I have followed to install "FTDI driver" and "AVR", those seems install corrected. But, whenever I connect the mobo board, and when my computer recognize, then my mouse cursor keep moving by them self and make program stuck, and I cannot do anything other than quit program......
I remember one time it worked fine and I did run some program in mobo...but, now becuase of this mouse moving problem and program stuck I can not do anything....please help! By the way, I am using window 7.
Caleb
Caleb
Welcome to the Parallax Forum!
What appears to be happening is that Windows is seeing data coming from the MoBo and interpreting it as mouse data. This happens sometimes, and it's strictly a Windows thing that can happen with any serial I/O device. Here's a post that details how to eliminate the problem in WinXP. Hopefully the same technique will work with Windows 7:
Thanks so much. It works. I spent 3hrs for trying before getting your advice. I should asked in forum earlier. Anyway, I can sleep tonight. Thanks again.
- Cheol
