Blink LED / Pulse 4026 based on Speed Word from Parallax GPS Module.
Hi All,
I am trying to make a VFD speedometer using a three Russian IV-22 displays. I am driving the IV-22s with 4026 counter chips chips. The Propeller pulses the input of the first 4026. The output of the first 4026 drives the input of the second 4026 etc. This displays the number of pulses as a 3 digit number.
I have connected the Parallax GPS module to the Propellor and used the GPS Smart Mode Demo to generate the pulses. The code also pulses one of the LEDs on the propellor demo board.
I have modified the GPS smart mode to display the speed in knots rather than convert the speed to miles per hour.
In GPS_SmartMode.spin I changed this:
To this:
If I write the code to display the number of satellites (which is a byte) the VFD display the number of satellites fine. When I change the code to display the speed (which is a word) the VFD doesn't display the speed and the LED on the demo board doen't pulse.
Any help is greatly appreciated.
Benoit
GPS_SmartMode_demo_VFD - Archive [Date 2011.11.14 Time 10.17].zip
PUB GetSpeed '' Speed is returned from the GPS module in knots; convert to MPH '' 1 knot = 1.1507771555 MPH return ReadTenthsAndScale(GPS_GetSpeed, 1.1507771555)
To this:
PUB GetSpeed '' Speed is returned from the GPS module in knots; return GetGPSWord(GPS_GetSpeed)
Benoit
Given the number format you might want to rethink the repeat GPS.GetSpeed in your BlinkSpeed method.
I was trying to keep the GetSpeed value as an integer as I thought a floating point value would mess up the BlinkSpeed method.
