Programing FT432H using C#
Hi
I am not sure that this is the forum for my question, but i try...
I have FT4232H mini module I am simply try switch on LED connect to Channel B (D6--> GPIOL2)
I know to verify the chip, I know to open the port but, I do not know to write '1' and switch the LED on
I am using C#
here my code:
[code][using
System;
using
System.Collections.Generic;
using
System.ComponentModel;
using
System.Data;
using
System.Drawing;
using
System.Linq;
using
System.Text;
using
System.Windows.Forms;
using
System.Threading;
using
DWORD = System.UInt32;
using
FTD2XX_NET;
using
FT_HANDLE = System.UInt32;
namespace
LedOnOff
publicpartialclassForm1 : Form
public Form1()
InitializeComponent();
// Variables
FTDI.FT_STATUS ftStatus = FTDI.FT_STATUS.FT_OK; //Result of each D2XX call
FT_HANDLE ftHandle; // Handle of the FTDI device
FTDI myFtdiDevice = newFTDI();
UInt32 dwNumDevs = 0; // The number of devices
UInt32 ftdiDeviceCount = 0;
DWORD uiDevIndex = 0xF; // The device in the list that we'll use
Byte[] byOutputBuffer; //http://msdn.microsoft.com/en-us/library/aa288453(v=vs.71).aspx
byOutputBuffer =
newByte[8]; // Buffer to hold MPSSE commands and data to be sent to the FT2232H
Byte[] byInputBuffer; //http://msdn.microsoft.com/en-us/library/aa288453(v=vs.71).aspx
byInputBuffer =
newByte[8]; // Buffer to hold data read from the FT2232H
DWORD dwCount = 0; // General loop index
DWORD dwNumBytesToSend = 0; // Index to the output buffer
DWORD dwNumBytesSent = 0; // Count of actual bytes sent - used with FT_Write
DWORD dwNumBytesToRead = 0; // Number of bytes available to read
// in the driver's input buffer
DWORD dwNumBytesRead = 0; // Count of actual bytes read - used with FT_Read
DWORD dwClockDivisor = 0x05DB; // Value of clock divisor, SCL Frequency = 60/((1+0x05DB)*2) (MHz) = 1Mhz
// Does an FTDI device exist?
ftStatus = myFtdiDevice.GetNumberOfDevices(
ref dwNumDevs);
if (ftStatus == FTDI.FT_STATUS.FT_OK) //Check status
//MessageBox.Show("Number of FTDI devices: " + dwNumDevs.ToString());
// If no devices available, return
if (dwNumDevs == 0)
// Wait for a key press
//MessageBox.Show("Failed to get number of devices (error " + ftStatus.ToString() + ")");
Status.Text =
"Not Connected";
else
//MessageBox.Show("device connected");
Status.Text =
"Connected";
// Determine the number of FTDI devices connected to the machine
ref ftdiDeviceCount);
// Allocate storage for device info list
FTDI.FT_DEVICE_INFO_NODE[] ftdiDeviceList = newFTDI.FT_DEVICE_INFO_NODE[ftdiDeviceCount];
// Populate our device list
ftStatus = myFtdiDevice.GetDeviceList(ftdiDeviceList);
// Open the second port by serial number
ftStatus = myFtdiDevice.OpenBySerialNumber(ftdiDeviceList[1].SerialNumber);
if (ftStatus != FTDI.FT_STATUS.FT_OK)
MessageBox.Show("Failed to open device (error " + ftStatus.ToString() + ")");
else
//Here I need to write to B6
/CODE]
I am using C#
here my code:
[code][using
System;
using
using
using
System.Data;
using
System.Drawing;
using
System.Linq;
using
System.Text;
using
using
System.Threading;
using
using
FTD2XX_NET;
using
namespace
LedOnOff
public Form1()
// Variables
byOutputBuffer =
byInputBuffer =
ref dwNumDevs);
if (dwNumDevs == 0)
Status.Text =
"Not Connected";
else
Status.Text =
"Connected";
else
/CODE]
