hot path in a H-bridge
Hi, there,
I have aquestion: Hardware developers discuss about the difficulties of a so called hot path in a H-bridge. Which kinds of difficulties are here discussed ?
This is probably the wrong forum.
A transistor does not stop conducting immediately when you stop sending current or voltage to it. If you turn on the other same-side transistor too quickly, EVEN IF THE LOGIC is correct, you can still have power being conducted through the wrong paths... and something will POP.
Be sure to consider the on/off times of your power transistors,drive logic, and all capacitance in the circuit when you do an H-bridge design. A slight delay between the OFF time of one transistor and the on time of another on the same leg is a good idea. If you don't want to mess with the calculations... you can include a variable delay, and "Sneak up" on an optimum a little at a time.
KB
Welcome to the forum!
If you want to explore the subject further with Google, use the term "shoot through" rather than "hot path". You might get more hits.
