PropBasic Wish List
Perhaps it would be useful to have a wish list for the PropBasic compiler.
So I begin with
1.
SELECT-CASE-END SELECT statement
Syntax:
SELECT CASE var
CASE test1 : statements
[CASE test2 : statements ]
CASE ELSE : statements
END SELECT
Example
Do
Input"Enter value (0-255) ", I
SelectCase I
Case 1 :Print"1"
Case 2 :Print"2"
Case 3 To 5 :Print"3-5"
CaseIs>= 10 :Print">= 10"
CaseElse:Print"Not in Case statement"
EndSelect
Loop
End
'note that a Boolean expression like > 3 must be preceded
'by the IS keyword
Example & Syntax is from BasCom AVR Compiler.
2. Continuation character to split long PropBasic lines.
Some other wishes anybody?
Cheers, Friedrich
So I begin with
1.
Syntax:
SELECT CASE var
END SELECT
Example
Do
SelectCase I
Case 1 :Print"1"
Case 2 :Print"2"
EndSelect
Loop
End
'by the IS keyword
Cheers, Friedrich
SD card support.
Especially with random access to elements in the file.
Duane
@Bean Probably a lot of work....
