Demo: Access the Propeller ROM
Hi, a small demo
what can I do, to set the code in a window with scrollbars, like other snippets here in the forum ?
// propeller-elf-gcc -mlmm -o readLogTable.elf -Wall readLogTable.c #include <stdio.h> #include <stdarg.h> #include <math.h> /* commented because does not fit in lmm float FractionalToFloat (unsigned short aNumber) { int x; float eps = 0.5f; float sum = 0.0f; for ( x = 0; x < 16; x++) { if ( (0x8000 >> x) & aNumber ) { sum = sum + eps; } eps = eps / 2.0f ; } return sum; } */ int main() { unsigned short * ptr; // ------ any info about the compiler ----------- printf("sizeof(char) %d\n",sizeof(char)); printf("sizeof(short) %d\n",sizeof(short)); printf("sizeof(int) %d\n",sizeof(int)); printf("sizeof(long) %d\n",sizeof(long)); printf("sizeof(float) %d\n",sizeof(float)); printf("sizeof(double) %d\n",sizeof(double)); printf("sizeof(int *) %d\n",sizeof(int *)); printf("sizeof(long *) %d\n",sizeof(long *)); puts("hit return . . ."); getchar(); // ------ read the log table 0xC000 .. 0xCFFF ------- ptr = ( unsigned short *)(0xc000); while (ptr <= (unsigned short *)0xCFFF) { //printf( "0x%X: 0x%X -> %f\n",ptr,*ptr,FractionalToFloat(*ptr) ); printf( "0x%X: 0x%X \n",ptr,*ptr); ptr ++; } while (1) putchar(getchar()); return 0; }
some issues are to complicated for me :nerd:
Thank you, David.
I see.
I am new here in the forum and a must say all users are very friendly and polite.
That is not the rule in other forums.
best regards,
Reinhard
