LMM Floating Point Demo — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2011-11-09 04:37 in Propeller 1
Here's a small floating point program that fits in LMM memory.
It is using double precision variables and the 64 bit library which is default code generation.
For some reason using the -m32bit-doubles option makes the program to big for LMM.
propeller-elf-gcc -o fpdemo.elf -Os -m64bit-doubles -Wall fpdemo.c -lm
propeller-elf-strip fpdemo.elf
ls -al fpdemo.elf
-rwxr-xr-x 1 steve sudo 30656 Nov  8 15:35 fpdemo.elf
Propeller Version 1 on /dev/ttyUSB0
Writing 30432 bytes to Propeller RAM.
Verifying ... Upload OK!
[ Entering terminal mode. Type ESC or Control-C to exit. ]
Simple Floating Point Demo
1.000000 * 1.000000 = 1.000000
1.010000 * 1.100000 = 1.111000
1.020000 * 1.200000 = 1.224000
1.030000 * 1.300000 = 1.339000
1.040000 * 1.400000 = 1.456000
1.050000 * 1.500000 = 1.575000
1.060000 * 1.600000 = 1.696000
1.070000 * 1.700000 = 1.819000
1.080000 * 1.800000 = 1.944000
1.090000 * 1.900000 = 2.071000
1.100000 * 2.000000 = 2.200000
1.110000 * 2.100000 = 2.331000
1.120000 * 2.200000 = 2.464000
1.130000 * 2.300000 = 2.599000
1.140000 * 2.400000 = 2.736000
1.150000 * 2.500000 = 2.875000
1.160000 * 2.600000 = 3.016000
1.170000 * 2.700000 = 3.159000
1.180000 * 2.800000 = 3.304000
1.190000 * 2.900000 = 3.451000
1.200000 * 3.000000 = 3.600000
1.210000 * 3.100000 = 3.751000
1.220000 * 3.200000 = 3.904000
1.230000 * 3.300000 = 4.059000
1.240000 * 3.400000 = 4.216000
1.250000 * 3.500000 = 4.375000
1.260000 * 3.600000 = 4.536000
1.270000 * 3.700000 = 4.699000
1.280000 * 3.800000 = 4.864000
1.290000 * 3.900000 = 5.031000
Here's the code:
 * @file fpdemo.c
 * Simple floating point demo.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
int main()
    double v1 = 1;       // assign to supress uninitialized warnings
    double v2 = 1;
    printf("Simple Floating Point Demo\n");
    while(v2 < 4)
        printf("%f * %f = %f\n",v1,v2,v1*v2);
        v1 += 0.01;
        v2 += 0.1;
    return 0;
  • RossHRossH Posts: 5,777
    edited 2011-11-09 02:29
    jazzed wrote: »
    Larger with 32 bit floats? That doesn't make any sense - there must be another compiler option you need to add.
    By the way, how do you find out with GCC how big the actual C program is? 30k seems very large for such a small program, but presumably that 30k includes all the drivers, the libraries, the kernel etc?
    edited 2011-11-09 04:05
    RossH wrote: »
    You can use the objdump utility to find the size of each of the sections in an ELF file:
    propeller-elf-objdump -h myfile.elf
    Here is an example of the results of objdump on fibo.elf:
    fibo.elf:     file format elf32-propeller
    Sections:
    Idx Name          Size      VMA       LMA       File off  Algn
      0 .xmmkernel    0000065c  00000000  e0000000  00002f78  2**2
                      CONTENTS, ALLOC, LOAD, CODE
      1 .header       0000000c  30000000  30000000  000000b8  2**0
                      CONTENTS, ALLOC, LOAD, DATA
      2 .init         000000ac  3000000c  3000000c  000000c4  2**0
                      CONTENTS, ALLOC, LOAD, READONLY, CODE
      3 .text         00002674  300000b8  300000b8  00000170  2**2
      4 .fini         00000038  3000272c  3000272c  000027e4  2**0
      5 .hub          0000074c  00000000  30002764  0000281c  2**2
      6 .ctors        00000008  0000074c  30002eb0  00002f68  2**2
      7 .dtors        00000008  00000754  30002eb8  00002f70  2**2
      8 .bss          00000220  0000075c  30002ec0  00002f78  2**2
                      ALLOC
      9 .heap         00000004  0000097c  0000097c  000000b4  2**0
     10 .debug_aranges 00000040  00000000  00000000  000035d4  2**0
                      CONTENTS, READONLY, DEBUGGING
     11 .debug_info   000012bc  00000000  00000000  00003614  2**0
     12 .debug_abbrev 00000338  00000000  00000000  000048d0  2**0
     13 .debug_line   00000254  00000000  00000000  00004c08  2**0
     14 .debug_frame  00000048  00000000  00000000  00004e5c  2**2
     15 .debug_str    00000018  00000000  00000000  00004ea4  2**0
     16 .debug_loc    0000154c  00000000  00000000  00004ebc  2**0
     17 .debug_ranges 00000178  00000000  00000000  00006408  2**0
    The stuff you care about is:
    1) .xmmkernel which contains the COG image of the XMM kernel needed to run the program.
    2) .header is a small header I put on all XMM programs that gives a tiny subset of the information from the ELF file. It is primarily used to find the start address and in flash/eeprom programs the address in flash/eeprom of the SRAM and hub initializers.
    3) .init contains the C startup code
    4) .text contains the program code and possibly constant data. We can also place COG images here that will later be loaded into a COG using coginit or cognew.
    5) .fini contains the C finalization code
    6) .hub contains data to be loaded into hub memory
    7) .ctors contains C++ constructors and any other code that should run before main()
    8) .dtors contains C++ destructors and any other code that should run after main() exits
    9) .bss contains uninitialized data and doesn't take up any space in the object file. It is initialized to zero by the startup code
    10) .heap is just the address where the heap will start.
    This program was compiled with -mxmmc (similar to Catalina's SMALL memory model) so all data goes in hub memory. If it had been compiled with -mxmm (similar to Catalina's LARGE memory model) there would also be a .data section containing initialized data to be loaded into external RAM.
    edited 2011-11-09 04:15
    David Betz wrote: »
    Thanks for the explanation David.
    RossH wrote: »
    You're welcome! By the way, in response to your comment about the complexity of the objdump output, you are absolutely correct. It's nice to have all of this detailed information but sometimes I wish for a more concise summary! The GCC tools can be quite verbose.
