Need help with switch logic code
Here is my code just for this discussions sake.
What I am trying to figure out is when the button is pushed (encdr.ispushed == 1) how do you make it so that the "1" that is set is not carried into the next routine? For example when it is in the Main loop and you rotate the encoder to "Routine 1" and then push the button it goes into routine1 and invokes"Option 1" right away and shows "Option 1 done".
Thanks. Don
OBJ
encdr : "encoder"
oled : "oleddriver"
PUB main
repeat
case encdr.read
1 :
oled.moveto(1, 4)
oled.str(string("Routine 1 "))
if encdr.ispushed == 1
routine1
2 :
oled.moveto(1, 4)
oled.str(string("Routine 2 "))
routine2
pri routine1
oled.moveto(1, 2)
oled.str(string ("Routine 1 "))
oled.moveto(1, 3)
oled.str(string ("Select option.... "))
repeat
case encdr.read
1 :
oled.moveto(1, 4)
oled.str(string("Option 1 "))
oled.moveto(1, 4)
oled.str(string("Option 1 done..."))
pause(1000)
2 :
oled.moveto(1, 4)
oled.str(string("Exit to Main Menu "))
oled.moveto(1, 2)
oled.str(string ("Main Menu "))
oled.moveto(1, 3)
oled.str(string ("Select Routine.... "))
return
pri routine2
oled.moveto(1, 2)
oled.str(string ("Routine 2 "))
oled.moveto(1, 3)
repeat
case encdr.read
1 :
oled.moveto(1, 4)
oled.moveto(1, 4)
oled.str(string("Option 1 complete..."))
pause(1000)
2 :
oled.moveto(1, 4)
oled.str(string("Option 2 "))
oled.moveto(1, 4)
oled.str(string("Option 2 complete... "))
pause(1000)
3 :
oled.moveto(1, 4)
oled.str(string("Option 3 "))
oled.moveto(1, 4)
oled.str(string("Option 3 complete... "))
pause(1000)
4 :
oled.moveto(1, 4)
oled.str(string("Option 4 "))
oled.moveto(1, 4)
oled.str(string("Option 4 complete... "))
pause(1000)
5 :
oled.moveto(1, 4)
oled.moveto(1, 2)
oled.moveto(1, 3)
return
Thanks. Don
PUB main repeat case encdr.read 1 : oled.moveto(1, 4) oled.str(string("Routine 1 ")) if encdr.ispushed == 1 release routine1 2 : oled.moveto(1, 4) oled.str(string("Routine 2 ")) if encdr.ispushed == 1 release routine2 pri routine1 oled.moveto(1, 2) oled.str(string ("Routine 1 ")) oled.moveto(1, 3) oled.str(string ("Select option.... ")) repeat case encdr.read 1 : oled.moveto(1, 4) oled.str(string("Option 1 ")) if encdr.ispushed == 1 oled.moveto(1, 4) oled.str(string("Option 1 done...")) pause(1000) 2 : oled.moveto(1, 4) oled.str(string("Exit to Main Menu ")) if encdr.ispushed == 1 oled.moveto(1, 2) oled.str(string ("Main Menu ")) oled.moveto(1, 3) oled.str(string ("Select Routine.... ")) return pri routine2 oled.moveto(1, 2) oled.str(string ("Routine 2 ")) oled.moveto(1, 3) oled.str(string ("Select option.... ")) repeat case encdr.read 1 : oled.moveto(1, 4) oled.str(string("Option 1 ")) if encdr.ispushed == 1 oled.moveto(1, 4) oled.str(string("Option 1 complete...")) pause(1000) 2 : oled.moveto(1, 4) oled.str(string("Option 2 ")) if encdr.ispushed == 1 oled.moveto(1, 4) oled.str(string("Option 2 complete... ")) pause(1000) 3 : oled.moveto(1, 4) oled.str(string("Option 3 ")) if encdr.ispushed == 1 oled.moveto(1, 4) oled.str(string("Option 3 complete... ")) pause(1000) 4 : oled.moveto(1, 4) oled.str(string("Option 4 ")) if encdr.ispushed == 1 oled.moveto(1, 4) oled.str(string("Option 4 complete... ")) pause(1000) 5 : oled.moveto(1, 4) oled.str(string("Exit to Main Menu ")) if encdr.ispushed == 1 oled.moveto(1, 2) oled.str(string ("Main Menu ")) oled.moveto(1, 3) oled.str(string ("Select Routine.... ")) return pub release 'wait for button release repeat until encdr.ispushed == 0
