Basic STAMP 2 and Relays.
Hello!
I am having a bit of a problem using the stamp to power on and off some relay switches.
What I am trying to accomplish is have the stamp turn on two relays at the same time
to power to other devices. I have used a transistor and it turns on one relay just fine.
When I mimic the circuit and try and turn two on (using separate pins) one will turn on,
but the other just 'vibrates'.
Anyone have any solutions?
Welcome to the forum!
It's a good idea to include a schematic or drawing of what you are trying to accomplish, so that we may have a look at it.
Also, including the code that you are using is a big help.
What is you power source? Batteries? Wall transformer?
Nice page on using relays with a microcontroller at http://www.kronosrobotics.com/Anotes/Relays.pdf
Info also applies to Stamps.
If you only need on/off, you can get 5V 20 mA SPST reed relays from radio shack and use them directly, no transistor needed. There are also rare DPDT relays (for instance, Aromat TF2-5V) that only use 20 mA and can be driven directly w/o transistors.
