Uncommon grounding issues
Hello.
I am having a little issue.
I am currently using the BOE revision D with a BS2 while designing and testing components of a circuit for a project.
I am triggering a 2n3904 to switch an LED on and off.
The LED is powered by 12V on a separate powered breadboard.
The LED has roughly 30 mA flowing through it, which makes me a little apprehensive about tying it to Vss on the BOE
The issue is this:
The ground voltage level of the Powered Board is roughly 5V higher than the ground voltage level of the BOE (Vss)
I have tried adjusting the -V source to use as a ground reference instead, but all that seems to do is increase the ground reference in reference to the BOE if that makes any sense.
Are my fears unfounded in tying all the grounds to the BOE's Vss or will that really burn out that pin at 30 mA even though the 12V (30 mA) source is originated from the powered bb?
Ack, that image is tiny, sorry.
The issue is this:
If this really is an issue, though, you can always resort to optical isolation to drive the LED.
