Running XMM programs from SD card
Is there any way to run an elf (or other format) xmm binary from SD card yet?
The reason I'm asking is that I'm trying to get RamBlade working with gcc XMM, but can't use propeller-load since the board needs to switch to different serial port pins between primary and secondary download.
I see there is an option to output "pex" file format, so I guess something is in the works...
I'm also working on an SD cache driver that will let you run XMM code directly from the SD card. That is a bit further off.
So, everything you are looking for is coming. Unfortunately, it's not here quite yet.
Thanks David
maybe you prefer to redo it yourself, anyway here's the (untested) driver.
"NEXT! - what's your name?"
"HX512 sir"
Running cached XMM directly of SD will be VERY nice...
