Windows v0_1_7 Now Available
Please see: http://code.google.com/p/propgcc/downloads/list
Windows PropGCC Distribution File - v0_1_7 (test only)
Dave Hein's c3files work is demonstrated here in LMM mode.
The propeller.h header is now included in the package. Contents are:
c:\propgcc>
- This package is 43MB and contains fixes for the "grep and .dll" problem.
- The propeller-load program now prints a banner for the terminal program like:[ Entering terminal mode. Type ESC or Control-C to exit. ]
- This includes updates to loader and board types.
- This includes c3files filetest for SD card.
- This includes propeller.h which has common propeller functions.
C:\>cd propgcc
C:\propgcc>echo %PATH%
c:\propgcc\usr\local\propeller\bin;c:\propgcc\bin;C:\windows\SysWOW64;C:\Program Files (x86)\Vim\vim
73;C:\bstc;C:\Program Files (x86)\Java\jre6\bin;C:\qt\2010.05\bin;C:\qt\2010.05\mingw\bin;c:\WinAVR-
20100110\utils\bin;c:\WinAVR-20100110\bin;C:\Microchip Starter Kits\PIC32 Starter Kits\MPLAB C32 Sui
te\bin;C:\Microchip Starter Kits\PIC32 Starter Kits\MPLAB IDE\VDI;C:\Program Files\Mercurial
C:\propgcc>cd demos
C:\propgcc\demos>cd c3files
C:\propgcc\demos\c3files>cd lmm
C:\propgcc\demos\c3files\lmm>make
filetest.o
dfs.o
dosfs.o
c3_cache.o
printf.o
c3files.elf
C:\propgcc\demos\c3files\lmm>mode
Status for device COM21:
Baud: 115200
Parity: None
Data Bits: 8
Stop Bits: 1
Timeout: OFF
XON/XOFF: OFF
CTS handshaking: OFF
DSR handshaking: OFF
DSR sensitivity: OFF
DTR circuit: ON
RTS circuit: OFF
Status for device CON:
Lines: 9999
Columns: 100
Keyboard rate: 31
Keyboard delay: 1
Code page: 437
C:\propgcc\demos\c3files\lmm>propeller-load -r -t c3files.elf -p com21
Propeller Version 1 on com21
Writing 27816 bytes to Propeller RAM.
Verifying ... Upload OK!
Available commands are help, cat, rm, ls and echo
> ls
HELLO
> cat HELLO
echo "Hello World"
> echo "Hi there!"
"Hi there!"
c:\propgcc>more usr\local\propeller\propeller-elf\include\propeller.h
* @file propeller.h
* This is part of the propeller library. ... this is a work in progress.
* Copyright (c) 2011 by Parallax, Inc.
* MIT Licensed
#ifndef _PROPELLER_H_
#define _PROPELLER_H_
#ifdef __cplusplus
extern "C"
#endif
#include "cog.h"
#include <stdint.h>
/* some defines for special purpose COG registers */
#define PAR _PAR
#define CNT _CNT
#define INA _INA
#define INB _INB
#define OUTA _OUTA
#define OUTB _OUTB
#define DIRA _DIRA
#define DIRB _DIRB
#define CTRA _CTRA
#define CTRB _CTRB
#define FRQA _FRQA
#define FRQB _FRQB
#define PHSA _PHSA
#define PHSB _PHSB
#define VCFG _VCFG
#define VSCL _VSCL
/* clock frequency define */
#define CLKFREQ _CLKFREQ
/* set CLKMODE */
#define CLKMODE(mode) (*((unsigned char*) 4) = (mode))
* start a cog with a parameter
* the fields in parameter are:
* 31:18 = 14-bit Long address for PAR Register
* 17:4 = 14-bit Long address of code to load
* 3 = New bit
* 2:0 = Cog ID if New bit is 0
* @param a - parameter value
#define coginit(id, code, param) __builtin_propeller_coginit( \
(((uint32_t)(param) << 16) & 0xfffc0000) \
|(((uint32_t)(code) << 2) & 0x0003fff0) \
|(((id) ) & 0x0000000f) )
* start a new propeller cog
* @param code - address of PASM to load
* @param par - value of par parameter usually an address
* @returns COG ID provided by the builtin function.
#define cognew(code, param) coginit(0x8, (code), (param))
* stop a cog
* @param a - cog value
#define cogstop(a) __builtin_propeller_cogstop((a))
* get a new lock
* @returns new lockid
#define locknew() __builtin_propeller_locknew()
* return lock to pool
* @param lockid
#define lockret(lockid) __builtin_propeller_lockret((lockid))
* set a lock
* @param lockid
* @returns true on success
#define lockset(lockid) __builtin_propeller_lockset((lockid))
* clear lock
* @param lockid
#define lockclr(lockid) __builtin_propeller_lockclr((lockid))
* wait until system counter reaches a value
* @param a - target value
#define waitcnt(a) __builtin_propeller_waitcnt((a),_CNT)
* @param b - adjust value
#define waitcnt2(a,b) __builtin_propeller_waitcnt((a),(b))
* wait until INA equal state & mask
* @param state - target value
* @param mask - ignore masked 0 bits in state
#define waitpeq(state, mask) __builtin_propeller_waitpeq((state), (mask))
* wait until INA not equal state & mask
#define waitpne(state, mask) __builtin_propeller_waitpne((state), (mask))
* wait for video generator to accept pixel info
* @param colors - a long containing four byte-sized color values, each describing the four possible
colors of the pixel patterns in Pixels.
* @param pixels - the next 16-pixel by 2-bit (or 32-pixel by 1-bit) pixel pattern to display.
#define waitvid(colors, pixels) __builtin_propeller_waitvid((colors), (pixels))
#ifdef __cplusplus
#endif
#endif
// _PROPELLER_H_
c:\propgcc>
