Magnetic Current Sensor
Hi guys,
I am looking for a cheap, light (very important), magnetic current sensor like this one:
http://www.rcplanet.com/Hitec_HTSC50_50_Amp_Current_Sensor_p/hrc55850.htm
It should be rated for 30~50 Amps. This is the only one I have found so far, but I'm sure there are more out there. All I have been coming across are giant current sensors. The sensor should also be non contact so it must be a magnetic one like this.
I was wondering do you guys know sites /stores where I might find more of these (perhaps lower current ---> lower cost)?
If you provide more details, maybe we could come up with a few ideas.
And that brings up another question... voltage. Is this an 11 volt lipo in a small 'setting' or a supply line to a 30 amp AC drive controller?
And by DIY I mean with available parts that you have to buy and connect together, or rip an old coil from many different broken electronic toys and devices, wrap some wire around it and make your own sensor, and use a few other parts to condition the signal for ADC or PWM conversion. Both are DIY... just different tools and costs.
Are you trying to measure motor current (brushed/brushless) or overall current for the total setup? And is this just for testing purposes, or for long term monitoring?
I am actually working on a project now, 3cell, 4 - EDF VTOL quad that has both an R/C and drone mode. Of course I am using 4 - 2100mah 30C in parallel. Not a huge amount of power, but one mistake.... and I might get hurt! Or a total of about 2 weeks of pay would become a memory with a bad math equation to blame.
I am thinking of a test type probe (which is the easiest, and I can alter others I already have), or a long term 'to measure and log to find problems later type of sensor'. I really want both. But I think time is going to limit me to immediate testing until I need monitoring for faults in a motor or ESC.
Both use the same idea, but are designed differently. You wanted light weight, so I am guessing you want flight sensors. So knowing if it is a single motor/esc, 2, or 3, or everything including CPU is the next question. And is this for a test setting (prototype) or a final solution?
Fun stuff. I love this part of the design.... the decision making over the finer details. It takes the most time, but it is the most fun.
http://www.sensorsmag.com/sensors/electric-magnetic/the-universal-current-sensor-1029
It explains the basics very well, even if a bit verbose.
Hey I had a quick look through the mental archives while I was cooking dinner. It was the first place I thought of while cutting onions. No insult to the article. I just needed a chopped onion when I was thinking about it.
