Bluejay
bluejay
I have a BS2 for a while. I plan to buy the Propeller Kit. Can anyone please send me an example of a code for a simple resistor and/or led, maybe a limit switch written in ASM and for the same hardware a code in SPIN. Because both ASM and SPIN are used by the Propeller, I would like to see how the codes looks like. Thanks.
http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain
Sometime I became stuck with a particular application. Help from several knowledgeable people on the forum was most appreciated.
You'll find many good tutorials in addition. There's a tutorial for PASM by DeSilva and numerous examples in the Forum. Check the sticky for more code. The HYDRA has some very good sections too.
http://www.google.com/search?q=propeller+tutorial+desilva&hl=en&source=hp&gbv=2&gs_sm=e&gs_upl=2289l12802l0l13072l27l25l0l7l0l0l186l1940l10.8l18l0&oq=propeller+tutorial+desilva&aq=f&aqi=&aql=1
