RCTIME Questions
I havea BS2 homework board and an rfid reader. I am working on range using the RSSI pin on my rfid reader. The reader outputs an analog voltage in the range of .5-1 volt based on how far away the rfid tag is away. 1volt being very close .5 volt far away. Anyway i was trying to convert the voltage to digital to read into the stamp with the RCTIME command. I eneded up with the wire straight from the RSSI pin going to BS2 pin 3 and it works without any resistor or capacitors. So i think i am running the RCTIME command on an analog voltage singal in the range of .5-1volt.
The RCTIIME is about 1600 with the tag about 20ft away. All i want is to determine if the tag is withing 20feet or out of the ranger being farther away then 20ft.
Here is my code
time VAR Word
Main:
HIGH 3
PAUSE 1
RCTIME 3,1,time
PAUSE 500
DEBUG DEC time, CR
IF(time< 1600) THEN
DEBUG "Out Range ", CR
ELSEIF (time > 1600)THEN
DEBUG "In Range",CR
ENDIF
GOTO main
My question is why does this work and will it continue to work accurately?
Here is my code
time VAR Word
Main:
HIGH 3
PAUSE 1
RCTIME 3,1,time
PAUSE 500
DEBUG DEC time, CR
IF(time< 1600) THEN
DEBUG "In Range",CR
ENDIF
GOTO main
