Command line help
I downloaded the Windows propgcc and extracted the folder and files to the C: root , I ran the addpath batch file and created the example blink.c
"propeller-elf-gcc -o blink blink.c" is not recognized at the command prompt.
Do I need to drill down to a certain folder and where should the blink.c and propeller.h be located.
tia
Jeff T.
tia
Jeff T.
Jeff T.
I'm not sure what might have gone wrong. Let me review the instructions briefly. I did these steps with the v0_1_5 package.
I see now that you have something working. Great!
It's probably good to post the rest of this message anyway for others.
Thanks.
--Steve
propgcc must be extracted to c:\
Open a new command window and it looks a little like below.
You must use "addpath" in every new window for now.
Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\> C:\>cd c:\propgcc C:\propgcc>addpath C:\propgcc>set path=c:\propgcc\usr\local\propeller\bin;c:\propgcc\bin;C:\windows\SysWOW64;C:\Program Files (x86)\Vim\vim73;C:\bstc;C:\Program Files (x86)\Java\jre6\bin;C:\qt\2010.05\bin;C:\qt\2010.05\mingw\bin;C:\Program Files\Mercurial C:\propgcc>copy con blink.c #include <propeller.h> int main() { int n = 0; DIRA = 0xFFFF; while(1) { OUTA ^= DIRA; waitcnt(CLKFREQ+CNT); } return 0; } ^Z 1 file(s) copied. C:\propgcc>propeller-elf-gcc -o blink blink.c C:\propgcc>dir Volume in drive C is OS Volume Serial Number is 6C8D-7E65 Directory of C:\propgcc 11/02/2011 04:44 PM <DIR> . 11/02/2011 04:44 PM <DIR> .. 11/02/2011 04:43 PM 66 addpath.bat 11/02/2011 04:43 PM <DIR> bin 11/02/2011 04:44 PM 6,722 blink 11/02/2011 04:44 PM 173 blink.c 11/02/2011 04:43 PM <DIR> demos 11/02/2011 04:43 PM 881 INSTALL.txt 11/02/2011 04:43 PM 2,678 README_WINDOWS.txt 11/02/2011 04:43 PM <DIR> usr 5 File(s) 10,520 bytes 5 Dir(s) 1,321,435,869,184 bytes free C:\propgcc>propeller-load -r blink -p com24 Propeller Version 1 on com24 Writing 2408 bytes to Propeller RAM. Verifying ... Upload OK! C:\propgcc>As a note I created the c file in a C++ IDE, can the examples be created with a regular text editor with the .c extension.
Jeff T.
Most decent text editors will let you configure "external tools" that will let you send your file to a compiler. There are quite a few available, but you can get Notepad++, Programmer's Notepad, PSPad for free on Windows. There's also Jedit and Komodo Edit, which are cross-platform.
