Passive IR Motion Detector output floats between off and on state
I have the motion sensor part# #555-28027.
I've tried this part both with a pull up resistor on the + side and without the pull up resistor, and the results are the same. The output floats between off and on state. What am I missing?
Do you have a resistor between the output and ground?
If I remember correctly, it sometimes helps to have something like a 10K resistor between the output signal and ground, and be sure to have the grounds connected between your sensor and your other devices.
are sure you have the sensor aiming at something that is cool and stable? These types of sensors can be sensitive to changes in IR light, changes such as sunlight flickering through the leaves of a tree, or a distant source of fire, like a distant campfire, flickering because of the wind or because of reflecting ripples on water. Even ceiling fans, etc. can sometimes cause them to go off because some unseen source of IR is being flickered by the moving air. Also, if the sensor is aiming at something reflective in the IR spectrum and you're behind the sensor and moving around, the sensor might see your reflected body heat.
What is the sensor aiming toward?
Can you post the schematic or maybe a photo of the circuit? Maybe it has something to do with how the LED is being driven. What are you using for a power source?
The circuit is just + to +, ground to -, and out to a pin on my connector socket, which I know is working from other uses.
A write up that I did a number of years ago, here might help (although all the pictures got lost in the forum migration): http://forums.parallax.com/showthread.php?109337-PIR-General-Activation-Circuit
The missing schematic from the link:
