From BOE to portable, real-world device?
I'm looking into the BASIC Stamp Discovery Kit (USB), and I'm wondering: How does one make the jump from doing the projects on the BOE to a portable, real-world device. Is that what the BASIC Stamp 2 Carrier Board is for: Program the BS2-IC Microcontroller Module, test it on BOE, then move module to the Carrier Board?
Thanks for any guidance.
Rob
Rob
If you're going to make more than a few, you can also save costs by using the OEM components rather than the BASIC Stamp Modules themselves. You can reduce your cost to well under $20.00 per BASIC Stamp using this method.
Mike: Are you referring to Item Code 27291?
Chris: Are you saying I can build my own BASIC Stamp instead of ordering a BS2-IC, as well as build the OEM board Mike was referring to?
Thanks again.
The BS2 OEM kit is what's known as a reference design. It's a known good design for people to use as a model for their own designs where the device will be made in quantity eventually. For single quantities, the module is better. It's already assembled and tested, has a built-in voltage regulator that can be used to power a small amount of external logic, and much of the documentation for the Stamps uses the module.
http://www.savagecircuits.com/forums/showthread.php?170-BS2-OEM-LITE-Schematics
