Low side mosfet driver for half bridge
Anyone have a suggestion for a low side N-chan MOSFET driver that does not require the source to be tied to ground? I am considering the PVI5033RPBF, but its rather expensive. here is a peek at the test schematic.
*Nodes A,B, and ref control the half bridge polarity - the 2 mosfets will be either fully on or fully off. Amp node is a circuit that uses a transistor with feedback to control current through the half bridge.
Attachment not found.
In fact, you could use one in both the top and bottom sides, with nMOSFETs in each.
That link is dead please re-post.
-P.
Thanks for the suggestion but I am just using DC to turn on the mosfets on / off so the freq = 0Hz.
Capt: I don't think this would work since I need to have a voltage greater than 5 on the gate with respect to the source.
