Precision Control of a Robot Encoders or Steppers?
What is the most precise method to control a robot? I noticed that the S2 incorporated the use of Encoders, would it be more precise to use Stepper Motors wihout feedback? I am just trying to get an idea of the best way to repeatably predict the exact location of the robot for a given set of commands.
I imagine the same is true for stepper, but rather than count pulses in, you count pulses out.
Preferably made of wood. I'm searching for Zebra wood with the perfect natural stripe spacing.
The Holy Grail of Robots, "exact location".
It doesn't matter whether you use a DC Motor, Servo, or Stepper with and encoder, they will all report revolutions. They problem is, if there is any slippage on the driving tires, you calculations on your final distance are not going to be valid.
You need to have a have have a homing, (reference) beacon to reference to keep a robot on course. This could be GPS, (not very accurate), or IR, (line of sight only).
I just happen to have a need for an encoder set-up, Now where did I put that circle glue-up jig?...
-Tommy
TCIII
