Memory Stick Logger 27937 and Bs2 pin connection without using Board of Education
Page 3 of the logger documentation (MemoryStickDataloggerV1.1.pdf) refers to pin connections when not using the Board of Education. I am confused by the the description of the pins for the UART Mode (assuming that is what I should use??).
My questions are:
1. What BS2 pin do I use when it says "connects to MCU CTS"?
2. What BS2 pin do I use when it says "connects to MCU RTS"?
3. Are there other components involved?
The other pins seem straight forward.
Ocean Bill
My questions are:
Ocean Bill
The BASIC Stamp can, when communicating serially, use hardware flow control by specifying optional flow control pins. These pins are described in the SERIN/SEROUT commands in the BASIC Stamp Syntax and Reference Manual. So instead of 2 pins you would be using 4 pins for bi-directional serial communication. I hope this helps.
