Need help with spin program
hey there,
i am new to the SPIN programming language, and need help with a little program...
i downloaded a program from the parallax website for the MS5607 altimeter and i need someone who is experienced with the SPIN language to modify it so it displays the altitude in meters on a 2-line,16 character LCD display as follows:
ALTITUDE <insert altitude here> M
i also got a program for the HMC5883L compass module and i need someone to modify the program so it shows the heading on the second line like this:
ALTITUDE: <insert altitude here> M
HEADING: <cardinal direction> <heading in degrees>
the cardinal direction can be N,S,E,W depending on the heading for example: HEADING: N 30 DEG
it should be possible by merging the programs into a single one and using a seperate cog for each process.
the programs are attached...29124_altimeter.spinHMC5883L_demo.spin
any help would be greatly appreciated
sincerely,
iloveBASIC
sincerely,
iloveBASIC
