Sending numbers
Hello,,
The code I am working on is the following:
This 'kind of ' works, however I was expecting the result of 060255255120120255 and instead I get an extra 0 at the end "0602552551201202550" . I could send each value one at a time with PST.Dec , but I would think there is a better way to do this, I am also using the PST object to display my results. Any ideas what I am doing wrong?
PUB testing
a := 0 '0-9
b := 60 '0-255
c := 255 '0-255
d := 255 '0-255'
e := 120 '0-255
f := 120 '0-255
g := 255 '0-255
outdata[0] := a
outdata[1] := b
outdata[2] := c
outdata[3] := d
outdata[4] := e
outdata[5] := f
outdata[6] := g
repeat i from 0 to 7(outdata)
PST.Dec(outdata[i])
Repeat i from 0 to 6(Outdata)
See if that helps:)
You're sending an extra value to the PST. Your data is from 0 to 6 but your sending 0 to 7. I assume outdata[7] is either zero or undefined.
I don't understand "repeat i from 0 to 7(outdata)".
Are you missing a comment before "(outdata)"?
Duane
Thanks again
I think this should work (I haven't tested it).
PUB Main | localIndex repeat localIndex from 0 to 999 if localIndex < 100 pst.dec(0) ' was ("0") if localIndex < 10 pst.dec(0) ' was ("0") pst.dec(localIndex)This should output a thee digit number with leading zeros when needed.
Duane
Edit: charleyshf's post made me realize I was using the dec method incorrectly. I fixed (I think) the code above.
Your example made me think about what I wanted the prop to do and this is working for me:
