Problem with Editor — Parallax Forums
Problem with Editor
mwlaursenmwlaursen Posts: 7
edited 2011-10-28 08:14 in BASIC Stamp
Do
DEBUG "Enter run time as a ",CR
DEBUG "number of pulses: "
DEBUGIN DEC pulses
DEBUG "enter Position as a",CR,
"PULSOOUT Duration: "
DEBUGIN DEC duration
image.tiff
I am getting this error when I try to send the program to the board.
The continuation after the CR, gets an error. And it does not understand DEBUGIN either?
New to this homework board.
Mark Laursen
  • Mike GMike G Posts: 2,702
    edited 2011-10-25 18:23
    I can't find anything wrong with your code other than the DO is missing a LOOP. Post all you code.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    duration  VAR   Word
    pulses    VAR   Word
    DO
      DEBUG "Enter run time as a " ,CR
      DEBUG "number of pulses:"
      DEBUGIN DEC pulses
      DEBUG "enter Position as a", CR,
    LOOP
    edited 2011-10-25 18:47
    Which version on the editor are you running? Get the latest from the website. It compiles OK on my computer.
    edited 2011-10-26 08:12
    Mark,
    Your picture doesn't show up for me and you did not say what the error was so I am going to go based on the code you posted. There are several issues with the code you posted that will return errors:
    • No Stamp Directive
    • No Syntax Directive, default is 2.0 which does not support some of the keywords you used. This will generate errors.
    • No LOOP for your DO
    • No variable declarations for your variables (pulses and duration)
    Once these fixes are made the code compiles just fine. Of course I had to guess at the variable sizes, but it is an example. I hope this helps.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    pulses    VAR Word
    duration  VAR Word
    DO
    DEBUGIN DEC pulses
    LOOP
  • mwlaursenmwlaursen Posts: 7
    edited 2011-10-26 17:41
    Ok, thanks for the replies, here the missing info.
    DEBUG "Enter run time as a ",CR,
    DEBUGIN DEC pulses
    The error is : Expected a constant, variable, unary operator. That is for the comma after the CR.
    DEBUGIN DEC pulses
    Error Expected ':' or end-of-line for the DEBUGIN, and it high lights the DEC.
    My Version of the editor is 2.5.2
    edited 2011-10-26 17:43
    Sorry I did not post the whole program:
    '{$stamp BS2}
    '{PBASIC 2.5]
    counter VAR Word
    pulses VAR Word
    duration VAR Word
    PAUSE 1000
    DEBUG "Servo Run Time: ",CR
    DEBUG "44 pulses in 1 second",CR
    DEBUG "Servo Position:",CR
    DEBUG " 350 <=PULSOUT Duratin <=1150",CR,CR
    Do
    DEBUGIN DEC pulses
    duration = duration MIN 350 MAX 1150
    DEBUG "Servo is running...",CR
    FOR counter = 1 TO pulses
    PULSOUT 14,duration
    PAUSE 20
    NEXT
    DEBUG "done",CR,CR,
    PAUSE 1000
    loop
    edited 2011-10-26 18:45
    mwlaursen,
    edited 2011-10-26 19:27
    Wrong formatting on the $PBASIC tag
    No "debug" in front of one of your statements
    I don't think the problem is with the editor.
    edited 2011-10-27 10:08
    Franklin wrote: »
    It all depends on your definition of "editor". :)
    ed·i·tor (d-tr) KEY
    NOUN:
    One who edits, especially as an occupation.
    Thanks, it was the '{$PBASIC 2.5}.
    I need to get my eye fix so I see better.
    Thanks again!!!
